It is the hardest part of the boat to work on. I would rather change 10 Merc seawater impellers over any task related to that cabinet.
On the top of the cabinet there’s a trim panel of 1/8” plywood. I removed this and pried the crown moulding off. You can try to remove screws from the black starboard strips but the cabinet is all joined with tabs so it’s hard to make meaningful progress.
Bring a 90 degree Phillips screwdriver and a ton of patience.
I didn't remove the entire console (which I considered!) but just had to work with that little slot between the stop of the console and the ceiling. Too high up to just get on tiptoes, and too high up on a small step stool...just uncomfortable all around and doing things in the blind. A removeable portion of that console high up would have been very nice to have.
Mind you, this is on a FV270. Not sure how similar yours is.
It's just those three amps. The TV for the hardtop had something in the access at the bottom of the port side hardtop. Yours was probably removed. I removed it when I installed the new TV, just left the speakers in the hardtop.
I am removing the cabin speakers as we don’t use them. Also considering relocating the head unit to the cockpit sink area but not sure it’s worth the effort.
