2003 Rinker 342 having trouble coming on plane
My 342 has the 5.7 mags and the other weekend I had trouble planning out. I did have full fuel tanks as well as a full water tank. I also had 12 people on board. I realize this is a lot of weight but my boat neighbors Four Winns 328 with 260hp engines came on plane easily with the same conditions. I had the outdrives trimmed all the way down and had the trim tabs down as well. I ended up sending people into the cabin to come on plane. Any suggestions to help the boat plane out?
You were pretty loaded up there.
raybo3 yes I had the tabs down before powering up.
2200 pounds of people
1800 pounds of fuel
400 pounds of water
200 pounds of food, ice, drinks and gear
3600 pounds
The 350MAG MPI has a top rpm of 4,800-5,200 rpm. My 22P gets me to 4,800 rpm. A 20P would get me to 5,200 or so.
20 pitch prop will red line the motor if you don't pay attention,carefull some of what you are reading is 4 blade compared to 3 blade
So just an update the Four Winns 328 that got on plane very easily just blew a motor. I don't think he has the correct pitch props on his boat. I think I will stay with what I have. I don't want to over rev the engines.
