2001 Rinker 340 3200rpm
1356
    Don't give up, take it back they must make it right. No test drive could have been done,
    @Carsnmorellc  I can imagine your frustration and disappointment. I agree with @randy56. - don't give up yet. There are going to be a couple of issues here that will get solved. There is a water intrusion issue. No way there should be that amount of water getting in. Agree with Randy that here has to be a leak. Also agree that the mechanics who installed the engines should trouble shoot their installation. Fingers crossed that it all comes together soon.
    If the water is coming from the front, it almost has to be from the fresh water system or the A/C system.  Should be no thru hulls up there.
    CarsnmorellcCarsnmorellc Member Posts: 230 ✭✭
    Ok so how do I get to the thru hulls to find or eliminate them?
    2001 340 Fiesta Vee 20P Hill Marine and 2 new 6.2 Horizon motors. Whine Down
    Ok so how do I go about getting to the thru hulls to check?
    Maybe its just the way the video looked to me but it looks like your putting your drives up instead of down. If drives are up you will never get on plane.
    aero3113aero3113 Member Posts: 8,864 ✭✭✭✭✭
    By looking at the gauges it looks like the port drive is up (just out of view in the video) and Starboard is down?
    I was able to get a screen shot, look at your trim gauges. You'll have to verify if your port drive is actually up or down.
    port drive is down, the gauge is busted.  I tried to not have it in the video cause I knew someone would comment. @aero3113
    Tabs down, Drives down, throttles forward. CHECK CHECK CHECK.
    New fuel filters installed? Fuel valves open to the correct position? Possibly fuel pickup dirty in tank? Just trying to give you some ideas to look at.
    Yes new fuel filters.  I'll double check fuel valves today.
    Clean bottom??
    Brand new bottom.
    I'd have those mechanics back on pronto.
    F1100F1100 Member Posts: 292 ✭✭✭
    watched the video, yeah something is very wrong. in my 300 with twin 350s, all I do is put the tabs down, I never touch my trim(its always trimmed up)  and then roll on the throttles and the boat pops up on plane very quick. Then back off the tabs.. and cruise.
    your boat is just plowing thru the water.
    Did you put a swim mask on, and actually have a look that your trim and tabs are working? and moving the full motion?
    @F1100 Yes is dumb as it sounds I keep a mask on just so I can see what's going on underneath.
    That's why I think that leak is something bigger than just a leak. I think the boat is waterlogged and thousands of pounds of water is stuck inside. Nothing else in my very limited mind makes sense.
    edited August 2017
    Not good to do but can you get past 3200 RPM in neutral? Never mind, I reread your first post!
    Yes the boat did plane out 2 times.  It took a good 15-20 seconds to get on plane, that might have been me easing her into it.  But when she did plane out it was literally amazing! hahahahahha I just need her to do it all the time.
    maybe pull the boat from the water and put it on a scale on the crane lift. And see what it weighs.
    @F1100 after this weekend thats the plan.  It sucks I want it to be the water weight cause thats what my head thinks but when that will probably be the most costly to repair.
    Have you tried going from neutral to full throttle in one smooth motion instead of easing into it? In your video towards the end I see you push the throttle full forward?
    @aero3113 I have tried both easing it up and pushing it up.  Neither worked, minus that one magical time.
    Once the rain stops I will go do more test passes and video tape them for yall.
    It could be something as easy as a corroded or loose ground. If it got on plane for you twice I would think its something intermittent.
    How low in the water does the boat sit when docked? If it sits low low then maybe but I find it hard to believe that there are thousands of pounds of water and you cant see it...... Just say'n.
    agree, I don't think the boat has enough wood core below the water line to hold thousands of pounds of water.
    A marine surveyor can do a moisture test - maybe even in the water from inside the engine compartment and inside the cabin through a couple of openings. That kind of water weight should have been evident from osmosis blistering, visible warpage of the hull lines and certainly when it was undercoated  (you say new hull - I assume that meant it was undercoated).  It seems like a simple (yet maddening) answer to me. Ground, throttle cable mis-adjustment not allowing full throttle travel - have you checked this?
    edited September 2017
    Ok so update!! We had a 2 hour gap of sunshine so I made a break for it and did a test pass.  Lets refresh, yesterday I came down. Checked everything from fluids to tabs to trim. Boat took off and planed in about 15 to 20 seconds. I was happy. Still not the 10 seconds yakk speak of but I also eased into it.  Went for 2nd attempt and I'm SOL all over again. So now we are all caught up.
    Today went to check everything and stuck my head under water and my tabs are neutral with the boat line..... everything else checked out.
    Tabs won't go down. I jumped in, pulled them down and they would not hold that position. Tried a test pass anyways... failed. Which pi$$ed me off since you don't need tabs to plane and I've upgraded the props and have no water on board. Gas is still full....
    So atleast we have some sort of lead....
    Post edited by raybo3 on
