Rinker 330/340 2008+ Random Topics
YYZRC
Member Posts: 4,925 ✭✭✭✭✭
Working on getting a decal made for the boat, could someone please tell me the width and height of the transom storage compartment (below the crease)?
Thank you!
Thank you!
Post edited by YYZRC on
@Aero, if you're messing around in the bilge, could you please look for a part number on the transducer? Trying to determine the angle as I need to replace.
Thanks!
I found the VHF "head unit" by accident, it is located behind the starboard side cover panel under the helm seat. It's a Standard Horizon PS1000.
All but one of the bolts holding the helm seat to the slide rails had fallen out, I replaced all bolts and used Loctite.
Is there a storage space somewhere for the salon table and legs?
It wasn't as bad as I expected to run wires from the engine bay to the helm.
I noticed that the fuse panel has a breaker for "thruster charger" - yay!
My AC unit is completely rusted out at the bottom and very noisy but still works. On the plus side, having the strainer not in the engine bay is nice.
The kitchen has absolutely no space for anything. Has anyone added drawers under the salon couch? Seems like it could work...
A heavy individual completely destroyed the underside structure of the couch in the salon, it needs a total rebuild.
All of the adhesive has melted off the velcro strips on the back of the aft cabin cushions and it's created a real mess.
That's all so far
I'm also pretty certain that the salon table is missing
How do I remove the factory-installed TV in the aft area?
Has anyone added a proper light switch for the head? The ceiling mount light is hokey.
I need to replace the microwave and I've seen some that are a perfect fit for the cut-out, any recommendations?
The down wash light switch is on the breaker panel.
The TV is mounted on a swing out door, I would think there are screws behind or try to lift and pull it off.
I believe this is the microwave that the previous owner of my boat installed (Double check the measurements). It fits the opening nicely, I just have to center it and put a lip on the cabinet so it won’t slide off.
https://www.lg.com/us/cooking-appliances/lg-LMC1575ST-counter-top-microwave-oven
We store our table and legs under the salon couch. Bummer about the missing table. it's nicely finished wood (although small for the size of the boat and no fiddles)
Our AC drain pan is still good, but from following this site now for 2 years, rust-out is a common problem. Poor design in drain so a little water always sits in it if you use it regularly. We don't, and where you live, you may not either.
Agree on limited kitchen space. This was a big disappointment for my wife. Our 28' Bayliner had more. But after using it 2 seasons we've gotten used to it.
We also had TERRIBLE problem with adhesives all over the back corner of mid cabin. I found WD-40 worked good on the thinner glued sections, and I think I used Goo Gone on thicker areas. Even then I had to use Magic Eraser along with the products to scrub out the glue.
Agree on light switch for head. Difficult to reach for short people.
Im hoping maybe the table is under the aft sofa.
That microwave looks good, will look it up!
