Rinker 330/340 2008+ Random Topics
17810121327
  • aero3113aero3113 Member Posts: 9,617 ✭✭✭✭✭
    edited March 2020
    My 242 was a lighter color than the 330.
    If you do use spectrum, follow the directions and it will come out perfect.
  • IanIan Member Posts: 3,003 ✭✭✭✭
    I used Lewmar 68000888/68000889 deck foot switches https://www.lewmar.com/node/11647 stainless cover. Work well and look good.
    edited March 2020
    Sadly, they don't offer the "patch paste".  I wanted to relocate the control for the spotlight but I guess that's off the table.
    Maybe buy the patch paste for my 242 and add some color to it to match?
    I bet once you done with a good match it will blend right in.
    Aero, do you know how deep the microwave cabinet is?
    I don’t, next time I’m out there I’ll measure for you.
    edited March 2020
    My boat has 3 underwater lights, all are physically broken or otherwise not working.  Honestly, I couldn't care less about the lights, except that I'm worried that they will leak. They are SeaBlazeX.
    I would replace, but they appear to be $300+ per light (?!)
    Any suggestions on a cheap replacement?
    Post edited by YYZRC on
    edited March 2020
    @YYZRC , sorry I forgot to measure the microwave inclosure for you! I’ll get it later today or tomorrow.
    I installed my new windless foot switches. I couldn’t pull out any wire to find the splices. I looked in the anchor locker behind the mirror, no luck. What I ended up doing was use the original wire and contacts. I just unscrewed them and was able to slide them out of the old housing and into the new, then screwed them into the new. The 3 screws and base are sealed with 3M 4200.
    Post edited by aero3113 on
    Looks great and ingenious approach!
    The puck in my toilet doesn’t return to the fully closed position after flushing and therefore doesn’t seal. If I give it a nudge with the toilet brush it will close up fine. What can I do to fix this?
    thanks!
    edited March 2020
    The base of the bowl has a clamp on it. Remove the clamp and bowl. Once the bowl is removed you can see if there is any thing that needs to be cleaned up. Also replace the seal, that can be holding it up.
    edited March 2020
    Thanks Aero! Looks like a shi**y project.
    @YYZRC my microwave is 16 inches deep. I wouldn’t go any bigger because the back top hits the curvature of the hull.
    Thank you so much!!  Looks like the microwave I was about to buy won't fit; 16" is quite shallow.
    I’m sorry it’s 18 inches!!
    edited March 2020
    And that’s including the door.
    Sorry, I’m getting confused with the pictures I took. I’m pretty sure it’s 16” LoL!
    LG LMC1575AST 1.5 Cu. Ft. Neochef Countertop Microwave Oven, 20" x 12" x 16", Stainless Steel
  • SpyderwebSpyderweb Member Posts: 948 ✭✭✭
    @aero3113 Nice job on the windlass switches.
    @YYZRC agree with aero on separating the 2 halves of the toilet to investigate.  And if you've gone that far, replace the gasket for the flapper and for the 2 halves.  My problem was the flapper had slight leak, and would not hold water.  The trickiest part for me was putting the 2 halves back together.  They developed a leak after replacing the seal (?).
    From my picture, there is a steel band clamp around 2 plastic pieces (making a circle) that holds the 2 porcelain pieces together.  When put together, the 2 plastic pieces won't meet all the way around.  There will be about a 1" gap on 1 end, or you can space it to have about 1/2" gap at both ends.  Some youtube videos made a real big deal about how to space them, others did not.  And also on which side to place the steel clamp screw. I would say try and replace it in the same positions as original.
    I ended up trying clamp in various positions before it finally stopped leaking.  Frustrating but finally worked.
    @Spyderweb , if you look closely at the plastic clamps, two ends have arrows pointing and says front. You put these two ends together at the front and there will be about an inch gap on the backside of the plastic pieces. Put the clamp on and tighten down.
    It should look like this when installed.
    If you look closely you can see the word “Front” on each side and the arrows.
    Wow, never knew that.  Guess those youtube videos aren't always complete.  So this would put the clamp screw in the back.  Not sure how mine is right now, but it wasn't leaking at end of year, so I'm not touching it.
    Thanks!
    Yea, when I first installed mine I had the gaps even on each side. When I tighten down the clamp that’s when I noticed it was marked. I found installation instructions online and it stated that’s how to install it. If yours isn’t leaking, let it be!
    @YYZRC , you should see if there’s any type of warranty for the lights. If Seablaze is a new company maybe you’ll luck out. $300 for a light is crazy.
    Maybe they can repair them for a reasonable cost?
    I sent them an email about buying just the "guts", will report back!
