Rinker 350/360 2007+ Random Topics
1…1011131516…34
  • goalie59goalie59 Member Posts: 356 ✭✭✭
    Nice. Now all we need is the weather
    she looks beautiful
  • YYZRCYYZRC Member Posts: 5,531 ✭✭✭✭✭
    edited May 2022
    H3O+ mounted. Need to add a skirt board to clean up the look. Will get the aluminum powder coated over the winter.
    great job
  • aero3113aero3113 Member Posts: 10,015 ✭✭✭✭✭
    @YYZRC looks great!
    I think I would leave it as is. A skirt might catch too much water while getting up on plane and at speed.
    Wow, nice job, awesome. I like how high it sits you will have no issues while getting up on plane.
    Thanks guys. @aero3113 the skirt will only extend down 2”; just enough to cover the upper aluminum frame and the bolt heads.
    edited May 2022
    The H3O is a good rig but the winch arm is very cumbersome and poorly designed. Also, the winch body isn’t stainless and for the extra $600 they charge for the upgrade from crank to electric I expected better. It looks like a bunch of parts from Amazon warehouse deals.
    Solar is wired up and anchor light done.
    it look very nice
    edited May 2022
    @aero3113 have you replaced the trucks in your cabin door? Wondering which size. The train rail on my door cracked this winter due to ice so I figure I may as well replace the trucks at the same time.
    @YYZRC No, I haven’t had to replace them.
    Rando cam is up!
  • LaReaLaRea Member, Moderator Posts: 8,077 mod
    Looks like it should be hanging from the belly of a Predator drone.
    Very nice @YYZRC !!
    edited May 2022
    Got the door apart to replace the trucks and train.
  • raybo3raybo3 Administrator Posts: 5,620 admin
    So did this truck work on the door? I am thinking about doing the door on my 342 but just cant figure out how the wheels would work on that track,
    Haven’t received them yet. Will post when done!
    @YYZRC great thanks for getting back to me. Hopefully they work.
    @raybo3 I am in the same mode. My door is getting hard to slide.
    @davidbrooks yeah I really hope this works.
    edited May 2022
    Did some calcs for putting a bigger fridge in the cockpit bar area and the Dometic CRX 80 will fit with some mods and killing the blender. Sink can stay for now but I will likely replace the countertop this winter with one piece.
    Ordered the fridge in stainless - supposed to arrive in a month or so.
    edited May 2022
    Added a dimmable “romance” light for late night dinner/drinks. It is wired with the cockpit lights. The other light is wired to the hardtop “spreader” lights circuit.
    The Blue Sea dimmer seems like a quality piece.
    Will mount everything nicely next to the starboard side speaker once I get the USB socket.
    @YYZRC , when you do you counter top upgrade, maybe make a bigger garbage pail??
    Since my custom starboard cabinet won’t work anymore, I was thinking about putting a garbage drawer next to the new fridge (where the old fridge was).
    That would be nice 👍🏻👍🏻
  • rasburyrasbury Member Posts: 9,001 ✭✭✭✭✭
    My track on the 270 is way different and to be honest, a better design..there are no wheels but a ball that rides on the top edges of the track. If the track gets crap in it, does not really cause a problem. Those wheels look like a problem.
    I was having trouble with mine when I first got the boat- I looked at the bottom track and it was loose- so I got her back down tight and the door well you could not budge it. The track on the top is nice and straight- the floor has a slight curve to it so we I got it tight it just bound up- so I got some washers and got it tight and flat...
    Blender recess is gone.
    I think this part might have been overbuilt.
    Some notes scribbled on by the Rinker factory.
