19293959798143
  • Dream_InnDream_Inn Member, Moderator Posts: 7,945 mod
    @LaRea thanks for posting this, as I’ve just redone my anchor rhode and now have 80 ft chain (instead of 20).  I plan to put back on boat sometime in the next couple weeks.  I will do the same as you, as I don’t plan to need all of it. I hope I don’t regret adding the chain cause I know I will now need to install a wash down or extend the cockpit one.  The chain loves to bring up mud!! 20 feet was easier to wash off while moving boat without the wash.
  • YYZRCYYZRC Member Posts: 5,460 ✭✭✭✭✭
    @Dream_Inn does the factory cockpit washdown use fresh water from the holding tank?
  • LaReaLaRea Member, Moderator Posts: 8,069 mod
    @Dream_Inn, we all hope to never need the extra chain, but it's the best way to add holding power.
  • rasburyrasbury Member Posts: 8,961 ✭✭✭✭✭
    Our river has come off flood stage so pending completion of a project those week hope to bring it home and get in the water!
    The cockpit wash down has its own seacock, so nothing from fresh tank. Right now I have the Seacock disconnected and use the pump to pull the last drop of water out of the bilge.  But I believe I can switch it back as I have been able to finally keep the bilge dry.
    I’ll probably use most of my chain, but not the line.  At least that’s the plan
    I generally put out most of my 60 feet of chain (anchoring in 5-15 feet above a muddy bottom).  If I have more than 3-4 boats on just my hook, I'll lay out another 30-40 feet of rope.  The 210-foot rode is overkill ... just the way I like it!
    You're right that the chain loves to drag mud.  Wish I had room for an anchor washdown.
    Sounds like an excuse...  :o
    Replaced the plastic end caps on my swim ladder.  They were both missing, and it always seemed like one false step would send somebody to the hospital.
    Mine are 1-3/8" for the 4-step swim ladder.  $6 each.
    https://www.amazon.com/gp/product/B09HSVK9TK
    With the boat out of the water, this repair takes 10 minutes.  Remove bolt, tap the cap into place, replace bolt.  I would not try it with the boat in the water!   ;)
    @LaRea, smart move on the end caps.  In a freak accident jumping into the water, my wrist caught the bare metal and sliced it open.  Also, although I replaced the cap in the water, I don’t recommend it.  Very easy for the plastic spacers/washers to slip out when bolt is removed.  Don’t ask me how I know.
    @Spyderweb - yikes!  I feel lucky it never happened on my boat.  And I almost tried to do the repair during the season, and decided not to.
    I replaced my end caps this past summer. Yep, one nut went in the water.  I now have an extra! (Cause I always buy a spare)
    edited January 2023
    Paid the first of three installments for our 2023 dock slip fees.  :#
    I dry store my boat for 75 bucks a month...on the trailer...
    No slip here. Stored in a barn of a family friend. I did start to get quotes on replacement canvas. I am also starting to compile a list of Ameritex part numbers for others to use for replacement canvas. If anyone has part numbers that they are willing to share, please send them to me. I will post here and on the Facebook group.
    edited January 2023
    It's winter, and we're all bored, so here's some eye candy:  Santa brought me a new ICOM M605 VHF radio.
    My old M604 suffered a problem that seems to be common for that model:  the volume switch was failing.  I sent the unit off to be refurbished, and then it will go on eBay.
    The M605 has all the things I loved about the M604:  great sound, numeric keypad, hookups for hailer and external speaker, and a rear-panel mic connector.  But the M605 is a new, modern, much better radio:
    • Obviously, the big color display is beautiful -- clear, bright, crisp.
    • Comes with a dedicated GPS antenna.  It's a 1-inch puck that I mounted inside the helm under the windshield.  It doesn't rely on my network or the ageing Raymarine RS130 up on the hardtop.
    • RX Play:  It can replay the last 90 seconds of whatever I was receiving.  If I missed something, I can go back and listen again.
    • RX Hailer:  This feature broadcasts the radio output over the hailer speaker -- handy for when we're hanging out on the foredeck.
    • Programmable softkeys for easy access to stuff I use often.
    Disadvantages?  Well, it's even bigger than the M604.  With a cutout of 3.5"x9.75", it consumes a lot of real estate.  To install it, I had to get out my reciprocating saw and create some sawdust.   :D   And it's expensive -- even without the optional AIS receiver, which I decided not to buy as we don't get a huge amount of commercial traffic here on the upper Potomac.
    These two factors make it a poor choice for most express cruisers, but I found a way to shoehorn it into the space and budget.
  • aero3113aero3113 Member Posts: 9,837 ✭✭✭✭✭
    Looks great!
    I like the replay feature.
    edited January 2023
    New AC unit with composite pan and sound shield. Ordered it last July and it finally arrived just before Christmas. Several boat bucks.  :|
    Going to bring mine home in the morning...change the oils...fuel filter...need to service the gunny also...cranks but is not moving water...
    I installed my new fridge today.  Very happy with it!
    I also installed my 80 ft of chain with 120 ft of line that I spliced together.  Also has the new mantus connection that fits nicely.
    Plenty of room in the locker for the additional chain.   I had to loo after @LaRea said he had to move the line around.
    Nice @Dream_Inn !! Did you have to pull your ice maker to remove/install?
    Thanks.  Fortunately I did not have to remove the ice maker.  It did take me a bit to figure out where the outlet was and plug it back in.  It helped that I have a large access panel under the sink on the side that I can climb halfway in to see behind ice maker.
    You’re going to love the Mantis swivel.
    I put one on last season but didn’t get to try it out. Planning to this year.
    @Dream_Inn
    Pretty sure you need to run some seizing wire thru/around that cap on the Mantus swivel.
    Good projects.
    Like the clean anchor locker. 'how you do anything - is how you do everything.'
    An anchor swivel is a must have. Totally eliminates the nasty binding and flopping around when retrieving.
    @mattie you can't see it in the picture, but I have a cotter pin that is thru the cap that is bent on the underside.  Thanks for checking though.  It's always good to have many other sets of eyes.
    I called Mantis to question the safety wire that was included. They said you can use it as a backup or instead of the cotter pin if you want. It’s thick wire that’s included, I was able to get it through and use both. If you zoom in, you can see it.
    Looks nice @aero3113 .  I didn't know both would fit.  I was concerned about the pin &/or the wire catching as it was retrieved.  I definitely have my key more in the groove than what you have, but mine is facing down as well.  Not sure any of that matters.  I may try to add the safety wire as well, but the key should be fine.
    I did knock the tabs down some after that pic. With the wire you can get them all the way down.
    @aero3113 where did you get that from and what size did you get?
