Rinker 350/360 2007+ Random Topics
1222325272833
  • YYZRCYYZRC Posts: 5,437 ✭✭✭✭✭
    Here's mine because its slow lol.
    My old boat had closed cooling like you do and the replacement housing backs were $$$. I was going to have the face of the housing back milled flat but sold the boat first.
    edited May 2023
    x
    edited May 2023
    x
    edited March 2023
    I designed this suction cup mount for positioning my dinghy alongside the boat. The white plate will mount permanently on the dinghy (I have two, one for each side) and the bracket is removable with the two wire pins. Theoretically it should hold the dinghy off the boat while allowing it to articulate with the waves and during boarding.
    Can’t wait to test it out!
  • LaReaLaRea Posts: 8,068 mod
    Nice work.  Powder-coated?
    You bet. Will likely add some sort of foam (pool noodle?) or maybe a rubber coating to the bars so it’s a bit more marine friendly.
    When do you go into full-rate production?  All you need is a manufacturer and an e-commerce website.   ;)
    I got the idea here: https://thehookcups.com/ and https://www.suctionup.com/
    Labor costs are insane up here. Could never make the math work. But it was fun.
  • aero3113aero3113 Posts: 9,799 ✭✭✭✭✭
    Nice @YYZRC ! 😎
    For safe measure, I would tie a line also (just in case).
    Yes absolutely will do.
  • Dream_InnDream_Inn Posts: 7,936 mod
    I would like to see how you are mounting the plate on the dinghy.  For me, I just use a line off the weaver davit.  If it’s rough I’ll use it with a piece of pvc that I use as a spacer (when it’s on platform).  I like the idea maybe to use with my cleaning raft/platform while I’m waxing the boat on the lift.
    edited March 2023
    The plate will be bolted under the seat - the slight bend is to allow it to extend out beside the seat above the tube.
    Good grief, that snow-white transom and shiny outdrives ... boat p0rn.
    LoL!
    Looks great @YYZRC
    @LaRea how about you drop a tiny hint about your new boat - I trust it’s not sterndrives so pods or shafts or…?
    Direct drive.  Big diesels and big nibral wheels.
  • Liberty44140Liberty44140 Posts: 4,414 ✭✭✭✭✭
    Direct drive tells me fly or trawler. Diesel”s” tells me likely fly…..
    No more hints for you!!  We started the hull survey yesterday and will finish today.  The engines will be surveyed Tuesday, and then it's decision time.  So far, we have a list of findings, but no deal-breakers.
  • raybo3raybo3 Posts: 5,614 admin
    @LaRea the list is probable stuff you were going to redo anyways...LOL
  • oscar1oscar1 Posts: 804 ✭✭✭
    It has to be big to take  24 hours to do a hull survey inspection
    Good for you, I also smell a great loop trip in the future......
    So I assume you are in FL helping with the survey?  I still think you better ride her back up the coast!  No better way to learn and break in a new boat!  Good luck!
    edited May 2023
    Tired of water that leaks in through the swim platform cleats pooling in a low spot so I filled it.
    edited April 2023
    The vacuflush timer is perfect. This is how it should have came from the factory. Pressing the button powers the vacu pump for a 5 minute interval. No more worries about the pump running all week when I forget to switch the breaker off and I’m not at the boat.
    @randallh82w8 pic of the cockpit table
    Nice table @YYZRC !
    I like the timer also, I might have to install one!
    @YYZRC , where did you get the switch from?
