1…115116118120121…145
  • Lake_BumLake_Bum Member Posts: 1,142 ✭✭✭✭
    Pat310 said:
    Thanks @aero3113. The product @YYZRC shows is the one I used. On sale on amazon 30% off.  Limited-time deal: Meguiar's Hybrid Ceramic Spray Wax - SiO2 Hybrid Technology in an Easy-to-Use Spray Application That Delivers Long-Lasting Protection - 32 Oz https://a.co/d/hkgTRLs   Some videos in amazon listing about application
    Crap! I clicked on this earlier and it showed the sale price. Now it shows full price, and I didn't order before 😂
  • aero3113aero3113 Member Posts: 9,937 ✭✭✭✭✭
    WoW, I did get the sale price.
    It's still only $20 with subscribe and save. Then you just cancel the subscription.
  • rasburyrasbury Member Posts: 8,986 ✭✭✭✭✭
    Start of gauge re do..i like the black..but screwd up and the tach has no hour meter. Can i add vv mobil and use both?
    @rasbury if you started off with a new hour meter it would start off at 0, the hours don’t transfer over from the computer.
  • PickleRickPickleRick Member Posts: 4,387 ✭✭✭✭✭
    @rasbury I'd be more worried about them being mounted upside down!
    Washed, waxed. Water tank full.  Engine test ran. New water pump. Half of the trailer bearings serviced, the rest will be done next week.  Now waiting on laundry to finish to put in fresh sheets/lake clothes.
  • IanIan Member Posts: 3,067 ✭✭✭✭✭
    Yesterday I finished the buffing at the stern so all done, touched up bottom paint, put lines and fenders on ready for launch with tires up to pressure on the trailer. A few more things to do but she can go in now, later this week I hope. Big challenge is the port rotor change - screws rusted in. Starboard cap and rotor changed, cap off port okay but may have to be creative with the rotor removal.
    @Ian can you cut a slot on the screws with a Dremel then use a flathead screwdriver?
    I've had good luck with finding a proper fitting screw driver and giving it a good couple firm taps on the end before trying to unscrew.  This is after soaking for a few days with your favorite brand rust penetration
    aero3113 sasid:
    So I can I use mobile vessel view along with the gauges, assume it will read ecm engine hours?
    That’s exactly right @rasbury  VVM will give you engine hours from ECM
    Sweet- I like the look of the gauges ...vv I will add mobile.
  • SimcoeRinker400SimcoeRinker400 Member Posts: 341 ✭✭✭
    When are you going in @SimcoeRinker400 ?
    @YYZRC
    Went in the next day. Been in a week.
    2015 Scarab 165G
    Laser Sailboat
    2002 Seadoo Explorer
    2023 Seadoo Spark Trixx x 2
    Added a hydraulic lift for the dinghy.
    @yyzrc  Can you send me the link for that I have 2 sparks but like to bring one on trips.          Like to have one that is also a step into the water.
    2015 Scarab 165G
    Laser Sailboat
  • YYZRCYYZRC Member Posts: 5,491 ✭✭✭✭✭
    edited May 2024
    That’s an option. We have a great mechanic at the club and he said he’ll get it out.
    @ian you need (and every boat owner needs) a hand impact driver.  That'll pop those screws right out.
  • Dream_InnDream_Inn Member, Moderator Posts: 7,952 mod
    My absolute favorite tool!  I keep mine in my van, so I have it home and at my boat. & it goes with me on boat trips.  (yes, I should just buy another)
    @ian you need (and every boat owner needs) a Dewalt 20v Atomic impact driver.  That'll pop those screws right out.
    Edited to out the Milwaukee fanboys.
    I like the Bosch.
    We aren’t all 1%ers!
    I got the Bosch impact driver, drill, and two batteries/charger for $99.
    I was talking about the kind that you hit with a hammer.  The impact cuts a deeper groove in the head of the fastener, and twists it at the same time.
    The hammer type is very useful
    oh ok.  I have two of those!  Very useful indeed!  Just the cheap harbor freight work well.
    These are star heads and I am not keen pounding down on the distributor…..
    I changed the impeller and coupler on my 5ECD generator. I highly recommend the tie wrap trick to help install the impeller. In the last pic, you can see the coupler hiding behind the pump if anyone was wondering where it’s located.
