2001 Rinker 340 3200rpm
So I took my boat out today and she would not plane out. The engines stopped at 3200 rpm in gear. In neutral they went all the way to 4500 rpm. Where do I start??
2001 340 Fiesta Vee 20P Hill Marine and 2 new 6.2 Horizon motors. Whine Down
is your trim gage working and are your drives up or down
yes check for power at the pump first.
thats if you can't hear the pump engage.
Then i would start right at the pump motor.
70 percent of the time pump goes bad. Solenoid Do go bad but it's pump or trim senders.
three wires there.
one neg and two pos.
two pos are triggers for clock and ccw rotation.
take a test light or volt meter and measure the voltage aka signal.
have someone at the helm actuate up trim and down trim
see if you are getting power. If you are then pump motor is toast.
easy to replace and cheap.
if none of those work then try your trailer override button to lower the drive and check for power.
if it moves to down pos then it's trim sending unit.
Couple things to watch out for...
I am careful loading the boat to not add any unnecessary weight to the stern. I keep life jackets under the bench seat in the back but that's about it...just the minimum. Heavier items I either leave at the dock or move well forward towards the bow.
When boating with a crowd I also limit my fuel (when possible) to only half full tanks with little to nothing in the fresh water tank. Also,a fresh pump out can make a difference as well.
Lastly i added about 100 pounds to the storage area under the forward bunk which helped as well. I know reading all of this makes it sound like a pain, but it's really not a huge deal once you are aware of it. Just be patient and experiment with what works for you. We love our boat and hope this helps!!!
if you were out this season and didn't have issues, then I don't think its a problem with the OD/props. A spun hub would allow the RPMs but not the speed/planing.
It could be a fuel issue not allowing the engine to hit max HP as well.
2 Questions:
What is a cool fuel system?
@ruwallydog so you are saying this boat may never go up on plane with 10 people on board and full of fuel? I've never liked leaving the gas tanks past half due to moisture getting in and etc. I also never have less than 8 people on board... now I'm 2nd guessing my purchase.
I totally get the frustration you are experiencing with the planing issue for sure!!! However, now that I am aware of how best to address it's essentially a non issue.
Shoot me a pm...happy to discuss offline. I spent a whole season banging my head over the issue and happy to help if I can.
I have included the link the previous owner posted a year ago so yall can read and have a better understanding of what is going on.
https://rinkerboats.vanillaforums.com/discussion/6157/engine-problems-on-a-340-fiesta-vee
although you did say it didn't have this problem earlier this season?
