Transom assemblies and engine room makeover
LaReaLaRea Member, Moderator Posts: 8,070 mod
[EDIT:  This project evolved into a major renovation, so I changed the title.]
I'm heading towards a long-deferred repair:  Both of my transom assemblies are leaking, and one side has heavy corrosion around the steering pin.  When I haul out for winter layover, I'll probably replace both transom assemblies.
My mechanic says he can probably do it without removing the engines (i.e. slide the engine forward).  However, I have a healthy list of jobs that would be easier with the engines out.  The boat's 13 years old with 820 hours on Merc 496s.  Here are some of the things I'd probably do:
Replace exhaust elbows and flappers
Fix minor corrosion on the engine blocks and accessories
Install wire looms for engine room wiring
Install better lighting in the engine room
Replace hard-to-reach hoses
Give the entire ER a general cleanup
What else should I consider if I pull the engines?
«13456716
    Consider the loan terms. LOL
  • LaReaLaRea Member, Moderator Posts: 8,070 mod
    My mechanic has a daughter in college ... somebody has to pay her tuition.
    I wonder if I should do starter motors.  No issues with them, but it'll never be easier than now.
    @LaRea check and maybe repaint the oil pans.
  • aero3113aero3113 Member Posts: 9,853 ✭✭✭✭✭
    @LaRea , I would do the starters. Like you said, would never be easier.
  • YYZRCYYZRC Member Posts: 5,464 ✭✭✭✭✭
    My coolant/raw water hoses are in rough shape. I would replace them if I had my engines out.
    Good call on adding lighting. Very nice to have. If your bilge is anything like my 342 was you may want to do the bilge pump too.
    Make sure the fiberglass around the transoms are true and flat
    Paint the floor of the engine room.
    Couplers. Depth sounder. Check hoses. Once the engines are out do as much as you can.
    I did both transom assy last fall. Went with the SeaCore ones.
    Curious as to what it cost to do the transom assembly. Don't need it but since it's brought up it has me wondering what something like that cost.
    Definitely the hoses.  I've had mine out a few years ago. Cleaning was my big thing, but I also replaced the padding under the generator.  How are the blower hoses?
    Ditto ... @Black_Diamond if you don't mind, how much did you pay for SeaCore units?  I haven't done a real search, but I saw retail prices at $3.2k each.
    At this point, pandemic availability becomes a factor too.  It might be worthwhile to wait a month or two, which is fine with me.  Just need to haul out early enough that they park me on asphalt instead of gravel.
    Added to the growing wish list:
    Starters
    Maybe replace depth sounder with a fishfinder
    Check transom is flat and true
    Couplers
    edited September 2020
    @Dream_Inn I did the blower hoses last month.  Definitely all water and hydraulic hoses.  And I might replace the insulation too.
    Your engine room is the Gold Standard to which I aspire.
    @Dream_Inn
    Well said, don't forget the pic of him a raft with the plam trees in the back ground.
    @LaRea. I can check my invoice, but that number sounds about right. For mine: pull both engines, they did a bit of fiberglass work at the transon assy holes, a few of the engine mount screw holes were stripped out 😱 so those fixed too. Replaced my one remaining original coupler with the HD one.
    Make sure they seal the new assemblies like Al has said to do.
    Definitely make sure it oozes out the sides around it.  Mine has some coming out all the way around.  Makes for a nice dry bilge!  I know need to change out my pulleys and then put new belts on.  That's one of my winter items.  Then I won't continue having all the belt dust.
    Opinions on SeaCore for a fresh-water boat?  It costs an extra $400 per side.
    And yes, I'll make sure there's plenty of oozing!  I read all 350 pages of the thread by @j3ff about his transom assembly leak.
    I'll probably replace the engine mounts too.
    You could just get the starters rebuilt. There is a great place in Alexandria.
    Are you talking about Virginia Pump?  I used them when I was running the yacht club's pool for a couple years.
    It’s right near Nicks nightclub
  • GMSLITHOGMSLITHO Member Posts: 1,618 ✭✭✭✭
    how about a drain hose from the oil pan I had one on my 270 it was a great feature
    A lot of people don’t like them but I do. My starboard pan has one but my port doesn’t. I like knowing that as much oil and moisture has drained out. I’ll also pour some clean oil in and let it drain out.
    They already have drain hoses.
    So i just looked at my invoice for when i did this in 2017.  I didn't go the seacore route though.  Labor was $3k to remove and reinstall both engines and Transom Assemblies.  One TA was around $2800 and $2k for the other.  The cheaper one was one i found on craigslist and had to drive to go get.  It was brand new still in the box.  The only thing was it was setup for digital senders and i had to just swap them out for analog.  Also replaced one of the engine couplers at the same time.
    So about 25 hours of labor?
    I'll display my ignorance about couplers ... can I inspect and replace only if needed, or should I just plan to replace them as a wear item?
    Replace
  • goalie59goalie59 Member Posts: 356 ✭✭✭
    Not sure where your generator is located but might be easy to do a complete service on it while the engines are out of the way.
    Not sure what I'd do differently from the annual, but you have a point.
