1…5152545657…146
    Great news Dan!
  • LaReaLaRea Member, Moderator Posts: 8,077 mod
    Replaced my cooktop that got busted by an airborne microwave turntable.  A bargain at only $350 from Defender.
    edited August 2020
    Ouch! @LaRea that reminds me. I had posted the idea earlier this year about using the child proof locks that are available to keep that door closed in the bumps. Yet I haven't done it yet. It just went to the top of the list.
    Edit: here it is. https://rinkerboats.vanillacommunities.com/discussion/11021/microwave-lock#latest
  • aero3113aero3113 Member Posts: 10,021 ✭✭✭✭✭
    @Willhound , I installed the child proof lock.
    Of course you did. If anyone has an idea then just ask aero cause he already did it. 😁. Such as my coffee maker that will be here Sunday ☕
    not only has he already done it.
    Its documented,photographed and archived.
    Dude smart and talented
    Indeed!!
    On my microwave, the door butts up to the coffee maker.  No way to use a child lock as shown above.  I'd love to hear suggestions for this.
    LG LCRM1240ST 12 cu ft Countertop Combination Microwave and
    Thanks @Aqua_Aura and @reneechris14 appreciate the comments. Anything I do to the boat I try to document and take pics. It’s a great reference if I need to look back and have any questions.
    @LaRea , I think it might work if you install it right under the handle up top. Looks like there might be enough space.
    You’ll have to unlatch it to use the coffee maker also.
  • J3ffJ3ff Member Posts: 4,244 ✭✭✭✭✭
    MiamiAG said:
    J3ff said:
    You guys and your waves... all I've got is the sunset..had to get the boat out of the canal to check on the growth on the NON-painted drive.. so far so good, a month in and just a wipe down with a sponge every 2 weeks is working.. have a call with the mechanic on Monday to figure out what we're going to do about this alignment mess. Either he steps up and takes care of it (remember he was the last one to have the motor out) or I'll be buying some harbor freight stuff and parts.. there's a marina down here that charges 80 a day to keep it on your trailer in their yard and will let you DIY. Hoping to find something a little more reasonable but that's the option for now.
    What marina, Jeff?
    Catamaran boat yard
    Replaced spark plug wires on the starboard engine, and will do the port side tomorrow.  Did plugs while I was at it.  I had noticed the wires had some chafing damage.  On inspection, it was worse than I thought.  Here are a couple examples.
    WoW @LaRea , I’m sure she will appreciate the new wires!
    edited August 2020
    I guess 14 years is a pretty good life for a set of wires.  From the looks of it, 10 would have been better.
  • GMSLITHOGMSLITHO Member Posts: 1,626 ✭✭✭✭
    That looks dangerous
    What a difference!  As an easy way to measure the boat's overall health, I look at cruise speed MPG on the VesselView.  I remember getting over 0.8 MPG in the past.  Lately, I've been getting 0.72-0.76 MPG, and I never knew why.  Last night I was back up at 0.81.  That's an improvement of 9%, just from spark plug wires!
  • YYZRCYYZRC Member Posts: 5,539 ✭✭✭✭✭
    edited August 2020
    Spat a belt at 4500 rpm having some fun in a relatively narrow shallow water channel. Starboard motor so steering bye bye. That sucked. At least I had a spare on board.
    It was a brand new belt a month ago so maybe it stretched and rubbed against another pulley?
    https://youtu.be/y--gGcAgev0
    @YYZRC , Didn’t you go with a Gates belt? Maybe that’s the issue? Strange for a new belt to fail so quickly...
    edited August 2020
    Yep I went with Gates.
    I suspect it was too loose.
    How's the tensioner pulley? Bearing good?
    Yep!
    Replaced my 13-year-old anchor rode.  The splice from rope to chain was getting worn from too many trips through the windlass.
    How many feet of chain did you go with?
    60 feet of 5/16" chain and 220 feet of 5/8" 8-plait.
    BTW a few years ago I upgraded from 30' of chain to 60', and it made a big improvement with how the anchor holds.  However, the 30' I added was actually the wrong size chain.  The links were 5/16" diameter, but slightly too long for my gypsy.  When bringing the anchor in for that final 30 feet, the gypsy would grab for two links, then the third link would jump.  It was really loud and annoying.
    Now I have 30' of 5/16" BBB and 30' of 5/16" G4, both of which fit my gypsy perfectly.  Very smooth and quiet.
    Bonus:  I stowed the other 30' of chain under the v-berth as ballast to help with balance.  Big difference!  Now I probably will not have to use trim tabs at all!
    I just downloaded the manual for my windlass, need to check the gypsy and chain. It has trouble catching the chain and skips sometimes as I'm pulling the anchor.
    Got a new manual toilet pump assembly coming and TV so those will be my Monday and Tuesday projects before we take our boat trip Wednesday.
    My rode is fraying where it connects to the chain. Next year...
    Anyone using the rode markers and what type? I hear various results with the tapes and I’m not sure they work well with 8 plait.
    I use these, and they work fine in 8-plait.  I don't mark the chain, because I always put out the entire 60 feet of chain.
    Anchor Rode Marker Set
