LaRea
Member, Moderator Posts: 7,931 mod
[EDIT: This project evolved into a major renovation, so I changed the title.]
I'm heading towards a long-deferred repair: Both of my transom assemblies are leaking, and one side has heavy corrosion around the steering pin. When I haul out for winter layover, I'll probably replace both transom assemblies.
My mechanic says he can probably do it without removing the engines (i.e. slide the engine forward). However, I have a healthy list of jobs that would be easier with the engines out. The boat's 13 years old with 820 hours on Merc 496s. Here are some of the things I'd probably do:
Replace exhaust elbows and flappers
Fix minor corrosion on the engine blocks and accessories
Install wire looms for engine room wiring
Install better lighting in the engine room
Replace hard-to-reach hoses
Give the entire ER a general cleanup
What else should I consider if I pull the engines?
Post edited by LaRea on
I wonder if I should do starter motors. No issues with them, but it'll never be easier than now.
At this point, pandemic availability becomes a factor too. It might be worthwhile to wait a month or two, which is fine with me. Just need to haul out early enough that they park me on asphalt instead of gravel.
Added to the growing wish list:
Starters
Maybe replace depth sounder with a fishfinder
Check transom is flat and true
Couplers
Your engine room is the Gold Standard to which I aspire.
And yes, I'll make sure there's plenty of oozing! I read all 350 pages of the thread by @j3ff about his transom assembly leak.
I'll probably replace the engine mounts too.
