2456716
  • goalie59goalie59 Member Posts: 356 ✭✭✭
    Remove or replace the pan. I would have loved to been able to do that to my 5e
    Definitely replace couplers.  You have a heavy boat like mine.  It's better to just replace items in that area.
    Not sure what I'd do differently from the annual, but you have a point.
    Remove and clean flame arrestor and clean out carb? Depending on where your Genny is, that side can be not so fun to get to.....
    You guys are awesome.  I can already see that this project will keep me constructively occupied all the way through the Season That Shall Not Be Named.
    I'm going to buy two engine stands.  Suggestions?  I saw some 1-ton stands for under $150, and I'm assuming any adjustable stand will fit.
    edited October 2020
    Here's the list so far.
    Drives:
    Replace transom assemblies
    Replace trim hoses
    Engines:
    Replace couplers
    Replace exhaust elbows, couplers, flappers
    Replace starters
    Replace water hoses
    Replace engine mounts
    Touch up engine paint
    Check compression
    Engine room:
    Install better lights
    Paint floor/walls
    Replace insulation on hatch and bulkhead
    Install wire trays
    Replace bilge pump
    Trace and label battery cables
    Generator:
    Replace rusted bolts on sound shield
    Inspect pan
    @LaRea is there an original transponder under the engine that went to the dash??? An old unit?
    One piece of advice that I learned the hard way is to make sure that when you paint you give yourself more than enough time for it to fully harden or you will find it on the bottom of your mechanics shoes and all over your deck.
    I don't see bellows and all associated parts listed. Was that already done recently? If you have it off definitely check the gimbal, u joint and bellows
    The transom assembly includes bellows, new rams, shift cable and all the other little bits and pieces.
    Handy - the depth sounder is forward of the engine, and very easy to reach any time.  I'll probably hold off on upgrading it to a fishfinder.
    On my 342 it was almost impossible to get to
    I have to do my port engine transom which is being leaking for some time. I am planing  to do it when i remove the radar arch so i can use a forklift to lift the engine out the bay compartment this off season.
    I can't get a camera down there, but I'm sure mine look like that if not worse.
    Today I built a set of temporary stairs for the estimated 2000 times I'll climb onto the boat over the next 4-5 months.  I have traumatic past experience with fall injuries, so I didn't mind spending a couple hours building stairs (mostly with materials leftover from other projects).
  • aero3113aero3113 Member Posts: 9,877 ✭✭✭✭✭
    Nice @LaRea !
    edited October 2020
    Good call on the stairs. That many times up and down a ladder your gonna trip at some point. Even just using a ladder occasionally you mess up at some point.
    That rise doesn't look to code in the photo and also you need a railing for that height 😆
  • YYZRCYYZRC Member Posts: 5,475 ✭✭✭✭✭
    You beat me to it! 6 7/8”!
    These stairs are fine obviously. Just joking around.
    I have built a hand full of stairs and railing and I have gotten better at it but my first experiences were for customers when I owned a steel fab shop and I absolutely hated it. Lots of small code to follow for every little aspect of stairs and especially railing.
    @LaRea you should consider having the hull painted. I will never have another non-white hullside boat that isn’t painted. Looks great all year, no effort!
    Haha you guys crack me up ... I probably will add a hand rail.  The 11" rise won't win me any prizes at the county code office, but it's the same as the swim ladder and just maybe a little bit safer.
    I also built a couple outdrive dollies like what @aero3113 and others have built.  My mechanic is going to pull the engines, and then I get to start the renovation work.
    With 820 hours on the engines, I guess I'll do a compression check to see if the top end needs attention.
    Thought about it many times.  I usually get the hull compounded and waxed mid-season ... didn't this year, and it really shows.
  • PickleRickPickleRick Member Posts: 4,376 ✭✭✭✭✭
    Is there a compiled list if part numbers for the common service items on the forum?  Im also doing bellows and gimball bearing.  I think @Alswagg liked one of the Sierra bellows over that of oem mercruiser.
    I plan on tackling all this after Christmas and would love to have part numbers lined up somewhere.
    Just the start of many ups and doens if know what I mean. Today I'm making a prop puller to start my pulling of motors. The stairs is a great idea.
    @PickleRick I've never seen one.  So many models and variations ...
    Very nice on the stairs, I’m sure someone in the yard will be happy to have em when your done or a nice to have for you for years to come.
    Isn't the sealed updated thicker sealed gimball bearing used on 98 and up models?  The bellows should also be same on be b1/2/3s id think. That covers most of us with merc stern legs.
    I think the yard will get a good deal on a flight of stairs, two outdrive trolleys and two engine stands.   :)
    @shawnmjr - You mean on the leftover deck boards that have already been gathering moss and slime for two years in my back yard?  Yes, smart idea.
    I’d probably install new blowers & ductwork as well when everything is out......maybe you mentioned that already.
    I think he needs to fix it then sell it and get his dream trawler so it’s paid off by retirement 🤓
    I did blower hoses this year and fans two years ago.  Handy I'd be allowed to buy a trawler only if it looks like a Rinker and cruses at 30 knots.
