Not my boat, but here's the location of the disconnect switch. The Anderson connectors are on the input side, i.e. the cables from the transom receptacles to the disconnect.
These are on the incoming lines at the back of the breaker panel on mine and also the connection at the water heater. Have replaced the shore power one behind board and at hot water heater with alternates, these are not good for movement I feel.
My takeaway for today: any time I lay eyes on one of these Anderson PowerPole connectors, I'll unplug it for inspection. If it won't unplug easily -- not good.
I had an electrical issue i was chasing last year with my 110 outlets. All of my outlets had the Anderson connectors on them. I did find a source for them but in the end it wasn't worth it. I basically did the same as LaRea. Then just replaced all the outlets and GFI's. Even if a GFI is outside rated it seems like they tend to go pretty fast being on the water.
Yesterday, I replaced the battery charger for the bow thruster. The old one wasn't fully charging the battery, which fits my theory that battery chargers only last 10-15 years. I went with a MasterVolt PowerCharger 12/20, which is a 20-amp charger that was on the shelf at the local West Marine.
When they installed the charger, the connectors were too small for the posts. Instead of installing the right connectors, they just clipped one prong off the connectors. Sloppy.
Today's adventure: outdrive go up, outdrive not go down. Well, since 2017 I've had a spare trim solenoid rattling around in the bottom of my parts box. Today I got to use it!
Well, my front isenglass is getting bad. I had somebody's old glass from the same boat that was in better shape, but they had gotten new cause they just couldn't get it to fit right.
Well, after years of holding onto it, I put it on last weekend after adjusting all the snaps on the windshield. Figured it was toasty under the cover and that was the time to try it out. The front center zippers were tight, so I only zipped part way down letting it stretch.
Went back down yesterday and it was better but still a large gap that wasn't going to zip at bottom half of both front sides. Today I took the zippers off the front center and moved them out, especially at the bottom. I'll try it out tomorrow. Ill see if I need to add more material over the zipper, but I think a little repellent spray may work if needed.
Some aspects of Rinker build quality are excusable due to the price point. This is gross.
Thanks @Pat310! I figured there may be something like that. This didn't take long to adjust and I've gotten pretty good the last few years doing canvas work (last winter I sewed in all new canvas over the original back). Those are a great idea though and I may need them at some point for another location (aft door is tight). They are definitely not cheap, but nothing is for boats, especially canvas. Actually now that I think about it, that isn't a terrible price for a decent zipper.
@LaRea are you sure that is factory? Did you buy brand new? Maybe the PO had it added. I have seen that many times before so it's not uncommon but usually after replacement of original parts.
2002 342 Fiesta Vee PC Point Of Pines YC Revere MA. popyc.org raybo3@live.com
I bought the boat when she was five years old, so I doubt the charger was a replacement. I can see clipping the connector on a 12-volt circuit, but it's really not a good practice for 110-volt power.
These days, most chargers don't use screw terminals for the input. There's a 3-conductor cable coming out of the box, and you just use butt connectors.
LED bulbs in main panel. Can you tell which side I did? Every day, I get a day older. The extra light really helps. Brighter, but not obnoxious. And now I can leave them on all weekend -- I think @Dream_Inn said that.
@YYZRC I haven't ruled it out. The boat and I have had this conversation every spring for the last few years! It's a $1200 conversion ... $2500 for props, then I'd net $1300 after selling my props. I also considered sending my 4x3 sets for reconditioning.
Thing is, I'm really happy with the boat's performance. Good hole shot, good cruise speed, good WOT speed. Yes, it could get a little better, but would it be $1200 better?
https://store.canvas-boat-cover-and-repair-advisor.com/ez-xtend-boat-zippers
I like the ID chart so you know what size zipper you have
So my canvas work came out great!!
.Here is what it was
Now...very happy!
