Newwire Marine. They are the Contrua XIV type not shown on website. Etched wasn’t going to work for me so called to ask about options and they offered these. Only Swim Platform was a special and they fit in Spreader as a full word, not Spreadr (or similar truncated).
Brought it home from storage Thursday but haven't even pulled the cover yet. Been raining non-stop. But can't find a cone-clutch so will likely put the OD back on and limp it through this season. Also want to pull my newly installed windlass and re-seal it cause I know I didn't do a good job when I put it together. Other than that need to clean, buff and wax and thats it. But having had hernia surgery 6 weeks ago I get sore quick still so will take my time
I guess one plus of Northern boating would be tge darned this is covered up 6 months are better...won't need as much buffing as mine does this season..never ending.
oops. forgot i have to re-install my seawater pump too. rebuilt it with a new housing and new impeller over winter. and install batteries. might have to get one of the kids to climb in there are i had hernia surgery 6 weeks ago. feel good and no restrictions but that house battery is heavy
For the boot stripe I used heat gun plastic razor and acetone because of the close proximity to other boats. For top stripe I am using whizzy wheel under the cover like @aero3113Definitely easier then heat gun. Took about 2 hrs each side for boot stripe
Where I store they get them a little closer, there’s very little between the rub rails. Getting to the stern is a near crawl on the floor. The yard manager has pushing in skills on the trailer rarely seen. Sadly he is the one injured in the explosion and fire in January.
As we have the same age and vessel I am keen to see if you have a shadow afterwards. Are you leaving off? I’d like to see end result photos to decide (or convince the admiral) to remove ours and not put back.
@ian my photo wont load either. I began buffing lower boot stripe area yesterday and was happy with the results. 3M heavy cut followed by 3M fine. Will post photo when I can
Not a great pic. Buffed up to about 4” before the through hull. Looking down at it from the dock it wont be noticeable I’ll post again when I get to the top stripe
Thanks @Pat310 good to know. @aero3113 I had seen yours also before but you’re around 5-6 years newer and wondered if the extra time would leave more of a shadow or non-faded line.
Anyone have a source for this Boot Stripe??? Boat Stripe Actual 1/4" navy blue 1/4" metallic gold 1 1/4" navy blue Total 1 3/4"
I did a quick look on eBay and found this. Not exactly what you’re looking for but I would call Great Lakes skipper (this seller) they have large stock of decals.
What I was going to do if I wanted to replace was 2” black and add 1/4” gold over top. I believe that’s how the original was made. Seemed thicker when removing where the gold stripe was.
From this:
To this:
I used a decal eraser when I removed mine, simple and quick! I needed 2 erasers to remove all of my stripes on my 330.
That picture looks very familiar!! 😂 Cramped with the shrink wrap on but doable!
https://www.ebay.com/itm/144484926868?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=PPsq0eSBQmO&sssrc=2349624&ssuid=jb9VSTJCQVS&var=&widget_ver=artemis&media=COPY
2015 Scarab 165G
Laser Sailboat
2002 Seadoo Explorer
2023 Seadoo Spark Trixx x 2
