18283858788132
  • IanIan Member Posts: 2,964 ✭✭✭✭
    I may ask to borrow your small child to get in there to change the duct :) - I got the duct, just cannot get me in there.
    @goalie59 what's the size of those props?  I'm just curious.  My B-2 drives, I have 19.5" dia 4 blades.
    They are 24 inch diameter by 22 pitch
  • Rinker310_LIRinker310_LI Member Posts: 22
    it’s possible. i didn’t think i could do it but was able to reach without use of small children. I don’t even think my 10 year old could fit through that door!
    2002 Rinker 310
    Well she is waxed up and ready for another boating season!!
    2008 Rinker 400 EC
    2015 Scarab 165G
    Laser Sailboat
    2002 Seadoo Explorer
    2023 Seadoo Spark Trixx x 2
    Hey Simcoe Rinker 400. When you were detailing your hull did you notice any very fine hairline cracks in the gel coat. My 410 has quite a few running from the rub rail down. I had heard that they are common on the larger Rinkers.
  • Dream_InnDream_Inn Member, Moderator Posts: 7,793 mod
    Are they where the sling would be placed?  I know in my marina a couple 410/420s that have them where the sling goes.  For some reason, I've seen that hull have them around where the sling goes.  I was told it was ok and just cosmetic.  I've gotten lucky and really don't have much on mine yet.
  • LaReaLaRea Member, Moderator Posts: 7,911 mod
    My 370 has them too.  Agree with @Dream_Inn it's a cosmetic issue.
    Dream. They are worse on the port side about 1/3 of the way up from the stern. I just had never noticed them on my 320.
  • Corral42Corral42 Member Posts: 62 ✭✭✭
    Having her prepped for ceramic coating. Considering leaving the stripes off
  • aero3113aero3113 Member Posts: 9,467 ✭✭✭✭✭
    Very nice @Corral42 !!
    I noticed an oil stain under your port drive, hopefully that’s old or not from you?
    Antifreeze when I lifted the drives to clean. I stopped abruptly Sunday when the detailer showed up. I have them all ready for the outdrive paint.
    edited May 2022
    Yesterday I hooked up the batteries, painted the drives and installed new anodes. I have new caps and rotors to install. I have a new starboard steering pump coming, Last season I had a slow leak into the bilge when the engine is running. I’ve checked everywhere for the leak and can find it. I changed the lines, the cooler is dry and the actuator is dry. There’s wiring under the cooler and actuator so I would definitely know if they were leaking, everything is dry. The only place I can see a little wetness is at the pump. Figured that’s the only thing left.
    Post edited by aero3113 on
  • YYZRCYYZRC Member Posts: 5,349 ✭✭✭✭✭
    @aero3113 why not just install a shorter belt and bypass the pump?
    Yes. Replacing a pump that does nothing but circulate it’s own fluid. I had to do that years ago too.
    I’m sorry I meant to say starboard pump!!
  • MojosBoatMojosBoat Member Posts: 102 ✭✭
    edited May 2022
    I added an amp and 2 speakers to my sound system on my 410. Speakers are for the swim platform.  I previously put a Fusion stereo and remotes in it so I added these on a separate zone.
    ALL IN AGAIN, 410 FV Twin 8.1 H/O MPI, V-Drives ,
  • rasburyrasbury Member Posts: 8,661 ✭✭✭✭✭
    I drove by mine today.....does that count for anything?
    Last week installed both batteries and installed the seawater pump with the new impeller. Today got a call from the shop saying they tracked down a cone clutch but he has to buy it retail from another shop since they are so scarce so he said it would be an extra $150 or so. So tonight buffed and waxed port side below the rub rail. Still have to do the rest but only have 1 week left to get it done and weather has not cooperated
  • MarkBMarkB Member Posts: 3,992 ✭✭✭✭✭
    Launched today  :)
    Man, that is nice!
    Those Fusion decks with different zones are nice.
    How’s it sound out back?
    Hi  Goalie59
    Yeah, I have the Rinker Gelcoat Cracks.  When I talked to the old dealer.  What he was telling me our vintage of boats they put to thick of a gel coat which caused the cracking that looked like stress cracks but was not.  My 342 had them also.  The 360 and 370 in the marine have a few also.   It's a Rinker thing. :wink:
    2008 Rinker 400 EC
    2015 Scarab 165G
    Laser Sailboat
    Installed a new overhead TV today onto the hardtop.  Android-based with Bluetooth so it can play through the Radio as it didn't have pre-outs for the built-in AMP.  Turned out really good.
    2008 Rinker 400 EC
    2015 Scarab 165G
    Laser Sailboat
  • J3ffJ3ff Member Posts: 4,162 ✭✭✭✭✭
    Test fit the new flooring
    Looks good @Jeff, who did you go with?
    Marinemat in Florida... Came out to 700ish shipped!
    edited May 2022
    That’s where I got mine, I thought it was MM. Great stuff.
    Post edited by Ian on
    edited May 2022
    I run MarineMat also .... its good stuff.
    Post edited by SimcoeRinker400 on
    2008 Rinker 400 EC
    2015 Scarab 165G
    Laser Sailboat
    It looks great. What tv did you use?
