I'm very happy I spent the time redoing it. I took my time and had it in my warm family room with football on. Spent a lot more time than it probably needed, but I know it is done right and even better than what I had. The connection from the chain to the rode was quite worn. I actually flipped my rode around and now the part that was always in the locker till the end is the first part that would go out. I don't plan to get out more than the 80 feet of chain I now have but it is nice knowing I have 200 ft total now of rode if I needed it.
I have the S2 mantus swivel (bought thru WM for $120) & yes it is overbuilt. It's crazy to think that I'm actually excited to try it out!
Thanks for posting @Dream@Dream_InnI don't think I have the patience to do that...lol but I will get my anchor line done this spring.
2002 342 Fiesta Vee PC Point Of Pines YC Revere MA. popyc.org raybo3@live.com
@raybo3 from what I've read, the challenge with the swivels is that you can't see if it's failing - especially the style I have. The failure point is often the link between the halves.
No doubt the Mantus is better built and less prone to this type of failure.
@raybo3 I bought the mantus specifically for that reason. It is way overbuilt. This past year I’ve rafted up many weekends with a 370 that had this mantus ( I talked him into buying it first). I was impressed after holding his 370, my 400, and a 390 many weekends, and it pulled out of the muck so easily but yet held and even set well.
@YYZRC Original swivel on our boat was that same style stainless piece in your pic above. The two halves had fused together with sand, clay & some corrosion. Not functioning at all. Galled the screws attempting to remove. Only fix was a hacksaw. Keep an eye on it....
What did I do? Broke something while fixin something else....working on my trim I stepped on my bilge pump and broke it. Actually had a replacement- but in working on that, found the float switch was not working...so now have to replace that but a good find. Last time I had an issue it did work...
I don't mean to hijack this thread, but @Dream_Inn's post resurrected something I think about from time to time. I have very little knowledge about cars and trailers (and boats) -- so can someone explain why you have to constantly maintain trailer wheels and bearings, but cars can go virtually forever without having to deal with the same thing? Are cars built differently than trailers? Just really have wondered this for a long time.
I agree with yyzrc, those are the main reasons. It’s also sealed better in a nice metal enclosure in the cars. Trailers also go bad cause they sit more and then lock up.
Immersing the trailer wheel bearings in water is h a r d on them over time. Especially salt water.
Also, trailer wheels are quite small in diameter meaning the trailer bearings run hotter.
I guess I get the smaller diameter, but what about horse trailers, work trailers, etc.? Those are also frequent maintenance and not subjected to water? So why can't they just build a better enclosure like @Dream_Inn says they do with cars? I would think the small upfront increase in cost would be offset by the annual maintenance costs and always worrying about the bearings burning up and having a tire fly off.
My trailer has 16” wheels and Dexter EZLube hubs. If you follow Dexter’s instructions, you can repack the hubs without removing the wheels. Took about 15 minutes per hub when I did it last summer. A lot of utility trailers have the same axle/hubs on them.
2008 280 Express Cruiser, 6.2MPI, B3, Pittsburgh, PA "Blue Ayes" Go Steelers!!!
Heavy trailers also have the option of oil bath hubs. Oil hubs are nice because they tend to run cooler (until something like a ballon string takes out the inner seal and they run dry, seizing the bearing and then friction welding the race to the spindle). Anyone have a 12k dexter axle kicking around for cheap?
Rinker sold but still have other boats Eastern LI, NY
I would much rather do boat work over trailer work any day. Plus taking a boat ride to test a fix is a lot better dragging a trailer around. With the warm winter we have had so far it should hopefully be early boating season.
https://www.mantusmarine.com/mantus-swivel/
Mantus Chain Swivel https://a.co/d/ecCuqVT
S1 = 1/4" to 5/16" chain
S2 = 5/16" to 3/8" chain
S3 = 3/8" to 1/2" chain
https://www.mantusmarine.com/wp-content/uploads/2021/03/Swivel-Assmebly-Insructions.pdf
@raybo3 in my case the S1 clears the windlass no problem - but I wouldn't want much bigger.
lolol
