I rebuilt my bulkhead a few years ago and the excavator keeps coming back there. Every time I move the machine to do another job, instead of taking it to my shop, it goes back to the dock for launching watercraft (and maybe some dredging when nobody is looking). The Grady still goes to the ramp (although with the new sling/spreader setup it might not) and the big boat goes to the marina since I do not have a travel-lift.
Rinker sold but still have other boats Eastern LI, NY
@Rich_ I started rebuilding my bulkhead last weekend and could of used your excavator. I borrowed one that is smaller and i am just a bit too close to the edge to be comfortable. If you see a news article about a guy in Annapolis having to be pulled out of the water you will know who it was.
New sink drain, moved one of my batteries to starboard for weight distribution and got my canvas back on after some adjustments. Had the sides extended down so I can add snaps and seal it over the window and extended upward to cover the bottom of the isinglass that was sun faded and cracked. Also had a couple small things done on the back canvas.
Drives mounted, trim gauges adjusted, trim limiter set, ready for water.
Wondering how you set the digital trim set points? full down full up and max trim while running. I dont have vessel view but added simrad chart plotter with nema connection, is there a procedure? Or will I have to hook up my rinda laptop and do it there?
I have the VV Link hooked to my Simrads. I don’t think you can get trim readings via NMEA. In the VV menus there is an offset for the trim gauge reading. I manually got the pucks as close to 0 as possible when fully down and set the offset from there.
Max trim when running is 21.75” ram length as measured from center of mounting pin to center of mounting pin.
The trim pucks on my boat are analog and digital. You just have to swap the connection at the transom.
She came out of storage yesterday so I went down and power washed the winter coating off. Planning to prep this week with a view to launch by the weekend.
My analog gages are working but no input from digital switch at least for nema display. I will have to see if I can set them with the rinda software once I get it in water.
Started prep - cleaned off scum line, removed old anodes, cleaned off drives, masked and painted. Then pulled out the A/C ready to install a new and hopefully quieter one.
Thanks gor asking @ian and figured I better get you a response before you got booted! Just kidding...almost 3 years since the accident. She is eating 100% on her own as of recent but still a long way to go for her- but thanks for asking
Yesterday fit new anodes to drive - yep, stupid only ordered one set so another one the way - and pulled AC duct out and fit new unit and hooked in wiring. New duct, pipe work and tidy up to be done, ran out of time.
I did nothing! While we were out of town this weekend, our dock neighbor power washed our dock. I owe him some libations when we bring the boat in a few weeks.
Pulled it out cleaned, gear oil, and anodes. Then had to replace the impeller after getting back to the boat house. I guess it was on its last leg and burnt up from being dry after pulling out of the water. Before and After.
How’s the young lady doing?
Also got my Vessel Safety Check.
