Rinker 390/400 2006+ Random Topics
124»
    how much more did you have to cut to fit the 80 cockpit fridge?  I just replaced mine a couple years ago and really like the newer model.
  • YYZRCYYZRC Member Posts: 5,475 ✭✭✭✭✭
    @YYZRC , do you know the size of the barb for the generator oil drain? 3/8”? I want to bring a piece of Tygon with me today.
    Pretty sure it's 3/8 yes.
    Where will you or putting the water heater?
    I'm going to move it to the port side. I've removed all the starboard side plumbing (aft sink, transom shower) and I'm relocating the freshwater inlet to the port side.
    edited September 16
    The 80 is about 1.5" wider and about 4" taller. You have to relocate or modify the port shorepower breakers to make it fit, and obviously you lose the grab handle.
    I picked up the CRX-1080 for $450 + $150 shipping on eBay:
    https://www.ebay.com/itm/236436180876
    It had some minor damage to the frame but I thought it was a good deal overall.
    So, my only issue with this would be weight.  So, if you like to anchor out (& use your shower), you will find out that as you use your generator, fuel lightens on stbd side.  As you use your head, it gets heavier on port side.  You will notice that your shower drain is on the stbd side of the shower.  I will sometimes run both motors off the port side if I know I'm going to have a long weekend and make a lot of use of the generator.
    We actually use the aft sink, but I understand if you don't want it.  Are you going to keep the aft shower on the swim platform?  & watch where you put the fw inlet, you wouldn't want it in the way going in/out of the doorway to the cockpit.
    edited September 16
    Understood. I think the weight distribution difference in my case will be minimal. I run an 11 gallon water heater which would be about 120lbs full. My house setup is lithium so the batteries (port side) will save about 50 pounds vs deep cycle flooded, offsetting about 1/2 of the water heater.
    But most critically, I will be mounting my hydraulic lift on the platform to carry my dinghy (700 lbs), and the motor is on the starboard side. On my 350, I always carry more fuel in my port tank to offset the dinghy motor weight bias. Will likely have to do the same on the 390.
    I have removed the transom shower. It's of no use to me, just another thing to winterize.
    Freshwater inlet moves to the port side (where the waste outlet is now). Power inlets also moved to port side (same as your 400). Waste outlet TBD (likely starboard side). Will be same setup as my 350. I use an Aquor inlet, totally awesome.
    Does this mean the waste tank will be on the stbd side? (so the waste hose will have to go across the beam)
    The aqour inlet looks great!  & yes, moving the power to the side is much better!  Not sure why they had it down below in the way, never understood that one.
    edited September 16
    The original shorepower location on the 390 is insane. I would love to know who decided that and why. In the captain's log I found, the owner replaced the inlets 3 times in a 10 year span due to shorting out. Not to mention the trip hazard.
    I will leave the waste tank on the port side but the outlet might be on starboard so yes the waste hose would have to run across the firewall. I have it this way on my 350 with no issues.
    edited September 16
    Fair amount of water leaking in at the stern end of the aft cabin. Pulled down the cabinetry and the vinyl wrapped plywood was soaked/rotten. Certainly doesn’t help that the boat doesn’t have canvas right now. Will try to track down the source.
    Edit: the cabinets were held in place with 26 screws. No wonder Rinker went bankrupt.
  • aero3113aero3113 Member Posts: 9,877 ✭✭✭✭✭
    @YYZRC , I noticed that your fuel injectors have 3 holes, mine have 4. I remember reading that there are different types. Are you sure you ordered the correct ones? I think the 4 hole is a newer version.
    I just remembered you have different engines in the new boat so they might be correct.
    @YYZRC , did you get your injectors off of amazon? I see I can get 8 for $75.00. Just hope they’re reliable.
    edited September 18
    Yep I rolled the dice on Amazon injectors. Not paying $200/ea for Merc. It’s just a Chevy!!
    Frezon 8×Fuel Injectors Fit For... https://www.amazon.com/dp/B0CHVG9HJB
    @YYZRC , my injectors look pretty good and I checked the solenoids, they’re opening and closing. I bought this tool and will try cleaning them myself.
    https://a.co/d/05pFeHjH
    edited September 19
    That's cool, please post results!
    I was quoted $25 USD per injector to clean/flow test.
    @YYZRC I highly recommend the fuel injector tester. It’s a great way to get the concentrated cleaner through the injector. A couple of them seem to spit a little at first then cleared up. I went through all 8, did them twice. I used Berryman B-12.
    edited September 20
    I bought some new o-rings off of Amazon but they were a little loose on the injectors. The old O-rings are in surprisingly good shape, I’ll probably end up reusing them.
    I bought these when I replaced my injectors in my 6.2s
    ACDelco 217-1588 GM Original... https://www.amazon.com/dp/B000C9LBKM
    I almost bought them but was reading the reviews and people were receiving dry rotted O rings. They worked well for you?
    Yep they were perfect.
    Rear AC unit removed. Carpet installed underneath it  :#
    edited September 20
    Water heater mounted in its new home. Sitting on starboard strips so it doesn’t rot out.
    edited September 20
    Shore power relocated similar to 330/350 with nice new Marinco inlets
    Bilge paint almost done.
    Looking good!!
