The lake we boat on has an island that was used as a grave yard back before the lake was built. Graves date back to war of 1812 and before. There are trails all along the island. I think this is a good weekend to try this along the trails then sit on our boat at anchor listening for screams. Peoele like to visit walk up the hill at night aswell as camp on it.
This joke may have been written by @Willhound ?????
A new and easy test for the horror of Covid-19 is doing the rounds and it's simple, quick and positive (or negative if you see what I mean).
Take a glass and pour a decent sized shot of your favorite whisky into it and then see if you can smell it. If you can, then you are halfway there.
Then drink it. If you can taste it then it is reasonable to assume you are currently free of the virus because the loss of the sense of smell and taste is a common symptom.
I tested myself 7 times last night and was virus free every time.
Thank goodness.
I will have to test myself again today because I have developed a throbbing headache which can also be one of the symptoms.
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, 'Oh sh -- '
ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their holes until you die of old age.
PLIERS: Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
BELT SANDER: An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS: Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race.
BAND SAW: A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws and butchering your palms.
PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.
UTILITY KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use.
****-IT TOOL: Any handy tool that you grab and throw across the garage while yelling '****-IT' at the top of your lungs. It is also, most often, the next tool that you will need.
https://www.amazon.com/Dometic-2932562065-Refrigerator-Door/dp/B00T36X5CW
A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort.
Will Rogers
Cooking lesson #1: don't fry bacon in the nude.
Anything is possible if you don't know what you are talking about.
A recent study found that women who carry a little extra weight live longer than the men who mention it.
Thank goodness.
I'll report my results later.
TOOLS EXPLAINED
to say, 'Oh sh -- '
of blood-blisters.
race.
the outside edge.
use.
https://www.wkbw.com/news/local-news/woman-claims-spider-caused-panic-crash-at-lasalle-yacht-club?utm_medium=email&_hsmi=92841066&_hsenc=p2ANqtz-_cML0vtABCN-0Qb9p3g_qkRHQPuSoOuYxPoMlarjOxVetnEsV9SlKzexuxoI9fzxr_raE6cDP9izpFgvX1aReTu-_f6g&utm_content=92841066&utm_source=hs_email
Free the titty, protect the city.
