1…102103105107108…146
  • aero3113aero3113 Member Posts: 10,027 ✭✭✭✭✭
    I bought mine from there as well last season for the cockpit. Great prices!
  • 04FV270riverrat04FV270riverrat Member Posts: 268 ✭✭✭
    Boat was running rough. This was max throttle the other night.
    New rotor, cap, wires and plugs in my 350 mag. #3 wire came off the plug pretty easy…not 100% sure it was connected, oh well now. New wires ohm’d at 7.5, old ones were between 8.5-12ohms. Boat runs great now!
    Replaced Ritchie compass on dash. Quick swap.
    Original compass had a crack & lost some fluid over winter. Weird.
    @04FV270riverrat
    Ran into something similar couple years ago. Instantly everything started to run bad.
    Caps/rotors/plugs, etc - on my replace list for every 3 years now.
    Looks great! but I gotta say the pillows look a bit wrinkled?  :o
    LOL, @Liberty44140 wins the Eagle Eye Award.  They are textured pillowcases ... did you really think the Admiral would tolerate wrinkled linens?!?   :D
    Hahahaha! I feel so relieved. Boat really looks cool all lit up
    @LaRea - How did you attach the lights to the rubrail and upper helm areas?
    @TonyG13 I love those lights.  They are so light and thin that I can run them along the hull with just a little piece of electrical tape every 4-6 feet.  (I use zip ties on the rails.)  They are strong enough to hold a lot of tension, and durable ...  I've had some of them for 4 years and they are good as new.
    https://www.amazon.com/dp/B07RBQ2KHH
    Looks great @LaRea !!
    That window would be both of my daughters (and myself) favorite spot to look out!
    @aero3113 I agree!  The windows are great, especially when underway.  The Admiral calls it "watching Wave TV".
    Today I tried to explain to a coworker that this boat will eventually be our retirement home for at least a few years.  She 100% did not comprehend.  Some people get it, some don't.
    We would love to do the same once we retire!
  • PickleRickPickleRick Member Posts: 4,402 ✭✭✭✭✭
    I cleaned the shower sump.  Was getting so bad the bilge was randomly kicking on.   Gross.  Not holding tank or toilet tank level gross but still gross.
    Replaces spark plug and cables and the burn fuel pump fuse box.
  • rasburyrasbury Member Posts: 9,008 ✭✭✭✭✭
    @mattie how much ? Mine had no fluid when we bought the boat 8 years ago? I looked into sending back to the factory...pretty much an eyesore...my boating does not require a compass but that sure looks nice...
  • johnny44johnny44 Confirm Email, Member Posts: 137 ✭✭✭
    @YYZRC that is fantastic!!!
    that should come standard. Will be standard on mine very soon
    Former Boat: 2008 350 EC
    Greenwich Bay, Rhode Island
  • YYZRCYYZRC Member Posts: 5,540 ✭✭✭✭✭
    Under $20 on Amazon and best part, I repurposed one of the screws holding the sound shield in place so only one screw needed! Lean operation here.
    @rasbury
    About $80 on Amazon, Ritchie F-50 Explorer. Comes in back or white. Pre-wired with 22GA wires for backlight.
    I was shocked it was so reasonable. Ritchie has quite a selection on their website if you want to upgrade.
    I don’t use it either…..just for looks. Been boating in this area for 46 yrs.
    LoL! @YYZRC great idea but swap that roll out with the blue shop roll from Harbor Freight!
    That’s big $$ @aero3113 - I thought Bounty was a splurge!
    I washed the boat and looked over the engine bay today. Beginning of this season I replaced a leaking starboard distribution tube, today I found the port side now has a drip. Must’ve happened during our trip this past weekend. I should’ve just replaced them both at the same time, luckily I bought two. Anyone replace one in the water?
    Perfectly stowed and ready to go when the Admiral boards this weekend. I guess we are now officially Chulux-heads!
    Nice!
    I used mine Sunday morning!!
    Last time out I went to transmit on the VHF and as soon as I did I lost radio and My Garmin GPS. I had the Garmin "professionally" installed. The Garmin power was wired to the VHS and all supported by a 3 amp fuse. This outfit did a number of jobs for me and every time I look , I find another surprise. Fortunately for the boating community they are out of business.
    Well that’s something…!
    What?
    I think the marine electrician must’ve been out sick that day so they had building maintenance do the job….
