Life lesson: ablative paint doesn't wash off your skin easily. If, however, you decide to enjoy some KFC after your ablative paint session, your hands will be clean in no time!
In rougher seas instead of just holding onto the wheel, I can now widen my stance and have one hand on the wheel and one on the bar to keep more stable.
Super easy: Just pulled the MFD, found a good flat spot, drilled and feathered the holes, put in oversized washers for backing, and lots of 3M clear marine silicone caulk...
Thanks all - I've been wanting to do this for a couple of seasons, just finally got the cahonies to drill into the helm without screwing it up, and it took all of about 15 minutes. Should have done it sooner.
I made up some templates out of transparent vinyl so that I could center the plates perfectly over the hardtop access holes. You know, in case @aero3113 stops in for an inspection.
Very OCD - which I prefer.
“The way you do anything - is the way you do everything”
today, I ripped out the old marinAIR unit and installed a new HVAC system by Webasto in my 310 . What a difference , super quiet ! Also replaced the old ducting.
the marina finished putting the docks in today and we followed them with the 342
Doesn't matter what you get stuck on your hands....bondo, paint, primer, caulking - it all comes off once you eat KFC.
Unfortunately you are ingesting it. lol.
